Engine Timing
Engine Timing
Postby Nezza » Mon Jan 12, 2009 7:46 pm
Hey
I have jus put a new engine into my starlet, i changed the distributor over as the old one was bung.
How do i get it firing off the irst cylinder for timing?
Nezza
Postby RS13 » Mon Jan 12, 2009 8:13 pm
Line up the mark on the crank pulley?
RS13
Postby Rob » Mon Jan 12, 2009 9:19 pm
If it is an ep starlet then the distributor will only go in one way, so just set it up same as the old one and you should be sweet
1990 ST185H - project
1996 VS Acclaim wagon
Rob
