HRT wrote:Easiest way is to not go to VTNZ
mjrstar wrote:i did this on my girlfriends ae111r corolla and it was a matter of attacking it from both the top and the bottom i took the intake pipe off from the throttle body and this gave a bit more room to reach under the inlet manifold.. what a pain in the @rse place to get to.. i think it was around $200 to get overhauled as they a sealed unit...
neo wrote:Really, a failed prop.valve.. sounds wierd (you have checked all the pads and bleed all the fluids I assume)
I'd just get the 2nd hand one off Santa's 20v fxgt
nope that wasn't it either, both calipers have just had new seal kits, which has swapped the pressure round the other way, and then it came back when the discs were swapped over.neo wrote:OK something really simple, who ever it is, wound the piston in/out to suit the wear on the pads eh?
