MRS auto clutch thingy setup
Postby KinLoud » Fri Jan 23, 2009 5:50 pm
Wondering how the clutch in the paddleshift MRS works.
Hydraulic?
Pneumatic?
Vacuum?
Electric?
Rubber band?
Just got a big attack of curiousness
Ken
Auck
021 408 863
Postby Nuty|Mike » Fri Jan 23, 2009 7:29 pm
try www.spyderchat.com or www.mr2roc.com or www.spydermagazine.com
Its gotta be in there somewhere
05 Mazda Verisa .....for the Family
Nuty|Mike
Postby fivebob » Fri Jan 23, 2009 9:47 pm
from the Toyota Technical Training Manual;
The transmission control ECU controls the pump assembly and the actuator assembly to engage or disengage the clutch and shift the gears.
The Hydraulic Power Unit assembly generates hydraulic pressure for the shift operating system and the clutch release cylinder.
Stroke Sensors : The gear shift actuator houses three sensors that monitor the shift stroke and select stroke of the shift and select lever shaft assembly, and the clutch stroke.
The sequential manual transmission uses a control by wire type shift lever. The shift position and the movement of the shift lever are detected through the combination of the four switches that are integrated in the shift lever position sensor.
Postby KinLoud » Fri Jan 23, 2009 9:56 pm
Thanks guys.
I thought that hydraulic was the most likely.
Thanks for helping me scratch my mental itch!
Ken
Auck
021 408 863
