is the car over heating?
AW11 and SW20 should in no way be getting hot!
also im pretty sure the outlet on the side tank is at the bottom of the rad. and inlet at the top.
youd need to put a temp gauge on the return water hose near the engine. it would sound to me you have some restriction or the thermostats an issue
ps. yes there stone cold at the bottom. heat rises.
pureadrenalin wrote:Inlet and outlet are both on the top as in the pic below:
http://carpron.com/multisite/d/347856-2 ... OR_OLD.JPG
pureadrenalin wrote:What radiator do you have fivebob, that has “inlet top left, outlet bottom right”?
pureadrenalin wrote:AW11 is “inlet bottom left, outlet top right”
