Side Drafts on 4age
Side Drafts on 4age
Postby DXROLLA » Tue Jan 27, 2009 7:34 pm
Hey just wondering what is needed to run them on a 4age? Is it as simple as just getting a manifold and bolting them up with fuel lines and linkage kit?
DXROLLA
Postby atmosports » Tue Jan 27, 2009 7:40 pm
You will need manifold,carbs,linkages,fuel lines, & a suitabl fuel pump & fuel pressure regulator,air filters etc. You'll also need to suss out something as far as ignition goes.
atmosports
Postby rwd_mayhem » Tue Jan 27, 2009 8:15 pm
you will also have to change dizzy - people usually modify 4k ones to make work.
current: 1975 Valiant Regel
previous: 1980 mazda 626, 4AGE AE70 sedan, AE70 sedan, mk2 escort, KP60 starlet, TE71 liftback X2
rwd_mayhem
Postby DXROLLA » Tue Jan 27, 2009 8:35 pm
Whats needed to modify the 4k dizzy? Do you need to run a return line for fuel?
DXROLLA
Postby d1 mule » Tue Jan 27, 2009 8:54 pm
talk to pal,side automotive, they midify the dizzys. they basically make a new base to mount it to the head tho. about $200ish.
d1 mule
