another injector Q...
Postby stalker » Wed Jan 28, 2009 6:40 pm
So did some searching and didnt quite answer my Q.
Whats the best injector size to use on a 4agTe (silvertop) with the aim of 250rwKw's??
Would 2jzgte vvti injectors (550cc) be good? Or would they be to big, or to small?? (im guessing to small rather than too big).
Most of the project cars on here seem to be running around the 550's, so I take it there arent any issues with these?
On a side note: does anyone know a rough price for "new" 2jz injectors? (just didnt want to bug Mark again for prices, and the toyota parts down the road dont appear to know what a toyota is sometimes...lol)
AE85.6 Levin - Project car Click Here
RZ Supra formully known as EMZ RZ
stalker
Postby RunningRich » Wed Jan 28, 2009 8:20 pm
Using what ECU?
Richard
http://gtfour.supras.org.nz
RunningRich
Postby 4agtepwr » Wed Jan 28, 2009 9:06 pm
550cc injectors will do 250kw sweetaz
Current ride: Sweeeeet Hiace. 3L power!!!!
Project: AW11 4agte, 410kw 555hp on 26psi
11.1 @ 125.5mph with more to come, As seen in Aug 2011 Performance Car, haha
viewtopic.php?t=61383
Huge thanks to Phil from NZEFI, Al and Brendan from Caraid and Hamish from Sheifield Cresent Auto
4agtepwr
Postby IH8TEC » Wed Jan 28, 2009 9:11 pm
i agree, 550cc injectors, i run 52psi base pressure with plenty left in them
Re: another injector Q...
Postby Crucible » Wed Jan 28, 2009 9:15 pm
stalker wrote:So did some searching and didnt quite answer my Q.
arent silvertop injectors side feed? not certain about 2jz vvti 550s, but I know the earlier stock 440s are top feed.
Crucible
Real Life Mechanic
Postby TRD_ZERO » Wed Jan 28, 2009 9:46 pm
2jz and 3sgte are side feed, 3rd generation 3sgte ones being 540cc i think
Previous:
TRD_ZERO
Postby stalker » Wed Jan 28, 2009 10:05 pm
I havent got an ECU yet...but will more than likely be the new G4.
And awesome! Good to know, cheers guys! :D
And yea, I was told that the vvti ones are side feed. (thats what I was told at least lol)
stalker
Postby Akane » Wed Jan 28, 2009 10:40 pm
I happen to have a set of 540cc USDM Supra injectors for sale...
Postby gasman » Wed Jan 28, 2009 11:14 pm
i got a set of 550 side feed for sale. $400
"What can possibly go wrong?"
gasman
Postby Crucible » Wed Jan 28, 2009 11:29 pm
stalker wrote:And yea, I was told that the vvti ones are side feed. (thats what I was told at least lol)
oh ok, The earlier 2jzgte injs are definately top feed but 440cc, cos I bought some to run im my old car but went with 13bt 550s instead.
Crucible
Real Life Mechanic
Postby escortman » Thu Jan 29, 2009 7:00 am
i ahve some evo2 510cc for sale $300 with plugs hint hint buy them :lol:
4x4 toyota blizzard offroader
escortman
Postby stalker » Thu Jan 29, 2009 11:32 am
Cheers for the offers guys!
I do already have a set lined up at the mo...but if that falls through, ill PM you guys.
Does anyone know what the part numbers are for the 2j injectors?
:oops:
stalker
Postby Py7h0n » Thu Jan 29, 2009 11:42 am
All 2JZ-GTE injectors are Side Feed
All 2JZ-GE Injectors are Top Feed
All 7M-GTE Injectors are Top Feed
Be warned the VVTI ones are a bit odd and are not the same as the non-VVTI ones (will not fit in the rails).
Py7h0n
Postby stalker » Thu Jan 29, 2009 11:47 am
Py7h0n wrote:All 2JZ-GTE injectors are Side Feed
Hmmm, ok, so does that mean that the VVTI ones wont fit my rail?
The ones im looking at (from what I was told) are: 2JZ GTE VVTI ones. Got a sort of pink-ish top to them.
stalker
Postby Crucible » Thu Jan 29, 2009 6:00 pm
huh? are you sure?
Im not saying you are wrong, but I bought some off a mate and they were yellow, 440cc, top feed and went straight into 4agze fuel rail. He upgraded his supra to usa spec turbos and injectors which required resistors to run them as low impedence. They were definately out of his 2JZGTE Supra cos he brought the whole fuel rail into work and I took the four out I needed as he didnt need them anymore?
Could be an odd model Supra maybe??
Crucible
Real Life Mechanic
Postby Akane » Thu Jan 29, 2009 6:49 pm
AFAIK the JDM Supra MKIV turbo is 440cc, while the USDM got the 540cc injectors.
Common upgradez for Gen 2 MR2's as they just slot right in, which I did in my case.
And the MR2 440's slot into some 4A-G's... which I dunno which ones but you 4AGE guys will know more about it. 440cc sidefeeds.
