safari oil pressure
safari oil pressure
Postby groupagt4 » Thu Jan 29, 2009 7:22 pm
Hi sorry not a toyota but its towing one :lol:
How much is it suppose to read mine is just around/over 3bar
also oil light on the left of the dash, is that a pressure warnig or a level warning
groupagt4
Postby matt dunn » Thu Jan 29, 2009 7:47 pm
If it's the type I'm thinking of, the pressure gauge and light sensor are in the one unit,
and they are not the best and crap out all the time,
do quite a few through work.
Postby groupagt4 » Thu Jan 29, 2009 8:52 pm
yea weird that my battery light and oil decided to play up same time. is 3 bar good oil pressure though
groupagt4
Postby Mr Revhead » Thu Jan 29, 2009 9:28 pm
is that idle? at revs? hot? cold?
Postby groupagt4 » Fri Jan 30, 2009 7:28 am
at idle its just below and goes to just above 3psi revd. stays about the same when hot
groupagt4
Postby evil_si » Sat Jan 31, 2009 11:22 am
groupagt4 wrote:at idle its just below and goes to just above 3psi revd. stays about the same when hot
psi or bar?
3 psi isnt good
3 bar is good
evil_si
