Will Bluetop head fit 20V Block?
Postby Allister S » Wed Feb 04, 2009 1:00 pm
Hey guys, I'm wondering if I can rebuild a full Bluetop engine with a Silvertop or Blacktop 20 Valve block, Oil pump and sump?
1. Will my Bluetop head bolt on? Which head bolts do I use? What head gasket?
2. Will my Bluetop crank fit the block? Will the 20V Oil pump fit the Bluetop Crank?
3. What about oil drains? Piston Squirters(need blanking off)? VVT oil supply need blanking off??
4. Oil filter fitting? Bluetop Water pump fit to 20V block?
5. Is the block height exactly the same??
Thanks, Al
NZ AE82 GL Liftback Tarmac Rally spec
NZ AE82 GT Liftback x 2
R32 Skyline GTS-t Type M Coupe
'07 Subaru Legacy GTB
'03 Runx 2ZZ-GE 6spd
Allister S
Re: Will Bluetop head fit 20V Block?
Postby matt dunn » Wed Feb 04, 2009 9:06 pm
Yes it will fit, with Bluetop gasket and head studs.
crank will fit block, but rods will not fit crank, presume oil pump ok, but not 100% sure.
No worry's with any of it. Leave squirters in, nothing else to blank off.
will all fit ok.
yes
Postby Allister S » Wed Feb 04, 2009 10:25 pm
Thanks for that.
Looking at using my Bluetop Crank, Rods and pistons(new) in a Silvertop block. I want to use the 20V oil pump as mine is pretty filthy.
My Blutop rods have Squirters as well? No problems with this?
Anything else to look out for?
Allister S
Postby 20v_rollaboy » Wed Feb 04, 2009 10:55 pm
Hi there Allister :D
I haven't re-listed auction yet, will wait to hear back from you. Did your mate get back to you about the engine specs?
20v_rollaboy
Postby rollaholic » Wed Feb 04, 2009 11:33 pm
the pistons need cutouts for the squirters, i suspect your bluetop pistons wont have them
can probably get some machined in
Postby ChaosAD » Thu Feb 05, 2009 5:49 pm
Why not run the silvertop rods and some redtop pistons?
ChaosAD
Postby Allister S » Tue Feb 10, 2009 10:44 am
Silvertop engine has spun 2 Big End bearings and damaged 2 rods and the crank.
Also early bluetop stuff is lighter (Crank and rods I think), and it's going to be a tidied up, rebuilt road car engine, so no need for extra strength.
There's an interesting writeup on Club4AG with a guy doing a "Blue print" Bluetop and using the Bluetop stuff with a later 7 rib block. Apparently Bluetop crank 1kg lighter than later ones.
Should know soon how Bluetop stuff mixes with Silvertop.........
Allister S
Postby rollaholic » Tue Feb 10, 2009 12:28 pm
i've got a bluetop at home im dismantling shortly, and a smallport in bits too.
i'll do some weighing and we shall find out for sure!
Postby crispy'86 » Tue Feb 10, 2009 7:38 pm
Would definitely need machining done for the pistons if using bluetop items. But yes as Matt said , it all works. even the 20v oil pump.
crispy'86
Will Bluetop bits fit 20V Block
Postby Allister S » Wed Feb 11, 2009 11:08 am
crispy'86 wrote:Would definitely need machining done for the pistons if using bluetop items. But yes as Matt said , it all works. even the 20v oil pump.
So it looks like the Bluetop pistons need a cutout in the skirt to clear the oil Squirters or I could blank them off. Any opinoins???
Good news on the pump as I wanted to use the 20V one.
Hmmmmm, anyone got some 256 or 264 cams :D ?
Allister S
Postby crispy'86 » Wed Feb 11, 2009 12:47 pm
You could either get slots machined in the pistons to clear the oil squirter nozzlles or, do what i did and cut the squirters off, braze up the holes and bolt them back into the 20v block. They wouldn't really be of any use other than to stop excess oil flowing out the oil galleries.
Will need to definitely, positively confirm that it is an actual 20v pump i tries. I'll have to try bluetop and 20v items. As i thought i had a 20v pump on the bluetop crank.
Will post back later once i can confirm
crispy'86
Postby crispy'86 » Thu Feb 12, 2009 9:25 pm
Hey Allister, i checked earlier tonight and the 20v oil pump looks same as the 16v oil pumps to look at externally. Fit both the 42 and 40mm cranks no probs 8)
Same end on both styles crank where the pump slides on and the pump slots are same.
crispy'86
