molex wrote:fhe rods are significantly larger, larger even than the 4efte rods.
Gt_189 wrote:wel i heard tht if u swap the 4efte block for a 5efe one it increases the size of the engine to 1500 turbo. but wanting to no which block u actually use? also wether it will fit str8 back in with out mods?
Dell'Orto wrote:molex wrote:fhe rods are significantly larger, larger even than the 4efte rods.
Thats not hard, 4EFTE rods are puny. 4K rods are substantially bigger!
molex wrote:Dell'Orto wrote:molex wrote:fhe rods are significantly larger, larger even than the 4efte rods.
I haven't seen 4k's put down 240wkw on a standard bottom end
