Supercharging the blacktop 20v
Postby -MATT- » Fri Feb 13, 2009 6:11 pm
Interested in getting a little more low down torque from my Carina GT with it's BlackTop 20v. Should I stick with a Toyota supercharger off say a levin or Trueno? Or go with an aftermarket unit?
What would be involved in having this done and any recommendations on workshops that are good for this?
Cheers,
Matt
-MATT-
Postby Dell'Orto » Fri Feb 13, 2009 6:14 pm
Search man, its covered heaps.
Postby xsspeed » Fri Feb 13, 2009 6:18 pm
Might as well get a decent responsive turbo matched up to it. Probably the same effort and cost.
Re: Supercharging the blacktop 20v
Postby Crampy » Fri Feb 13, 2009 7:09 pm
-MATT- wrote:Interested in getting a little more low down torque from my Carina GT with it's BlackTop 20v. Should I stick with a Toyota supercharger off say a levin or Trueno? Or go with an aftermarket unit?
Cheers,
Matt
Easiest way (cheapest) to get more down low on a Blacktop, is run it on 98 or Gull Force 10 gas, tweak the timing possibly and change the trumpets for some I-Mec ones or similar. If trumpets are used in conjuntion with the stock surge box, it's been proven to give more down low as well as a good gain up high too. Best of boths worlds.
Turbo or supercharger will cost lots and the stock motor has problems with boost. Eg, conrods and 11:1 compression.
Crampy
Postby Crampy » Fri Feb 13, 2009 7:10 pm
Or, sell it and buy a car with a 4AGZE in it.
Crampy
