Ke corolla diff housings
Postby AE82 FXGT » Fri Feb 20, 2009 12:30 pm
Hey guys,
Quick Q, are ke30 and ke25 diff housings interchangable, as in bolt up?
If not what sort of alterations are we talking about?
AE82 FXGT
Postby l1ttle_d3vil » Fri Feb 20, 2009 1:25 pm
ke25 shocks bolt straight to the diff.
ke30 shocks bolt to the plate which sits under the springs.
depending on which way you're swapping, it might still work though.
I think ke25 axles are shorter than ke30 too, but axles/heads will fit each other, just can't use ke25 axles in a ke30 housing and vice versa.
