Toyota turbo technology research
Postby KinLoud » Fri Feb 20, 2009 8:58 pm
Really interesting!
Discussion of an electric motor integrated into the turbo to help spool it up from low rpm.
Compounding turbos - small and large turbos in series... small blow into large...
http://autospeed.com/cms/A_108916/artic ... larArticle
Ken
Auck
021 408 863
Postby Akane » Fri Feb 20, 2009 9:42 pm
Nice, cheers!
Postby sergei » Fri Feb 20, 2009 11:26 pm
I have an idea with that system, make the electric motor operate at ~500v then the current will be manageable. When the turbo spools down at the right condition (so it will only happen under engine braking) capture that energy back into super capacitors...
Postby FLAWLES » Sat Feb 21, 2009 10:47 pm
iveco trucks run a set kinda like that
very very trick
FLAWLES
Postby RomanV » Sun Feb 22, 2009 1:40 am
Autospeed is definitely one of the best tech sites on the internet!
Postby KinLoud » Sun Feb 22, 2009 9:48 pm
Postby frost » Sun Feb 22, 2009 10:33 pm
good read, thanks kinloud.
air bearings!!!
