20 valve using oil
20 valve using oil
Postby fj40cruzapete » Sat Feb 21, 2009 5:25 pm
ok the mrs has a 92 fxgt 20 valve silver top and its using lotsa oil
im thinking worn rings?????
something else maybe?
also the little engine light came on so drove home from where i was turned it off and turned it back on again and it had gone any reasoning for this? topped up the oil tho so maybe that had something to do with it?
cheers pete
fj40cruzapete
Postby RS13 » Sat Feb 21, 2009 5:52 pm
In the engine bay, stick a wire between te1 and e1 on the diagnostic port next to the afm, turn the ignition on to 'acc', the engine light will flash the corresponding code. It will either constantly flash if no codes, or go say, flash.. pause.. flash flash flash flash flash longer pause.. then repeat, this would be code 15.
Using oil.. if it isn't leaking it, then its' burning it, so its' rings or valve stem seals or whatever, get a compression test done and compare against factory specs to determine engine condition. If thats' okay, then it may be valve stem seals. :)
RS13
Postby Lanius » Sat Feb 21, 2009 7:24 pm
20 valve 4age's are known to use oil btw. As RS13 has pointed out, its probably due for a rebuild anyway.
Lanius
Postby AceSniper » Sat Feb 21, 2009 7:44 pm
oil rings
AceSniper
Postby Bling » Sat Feb 21, 2009 8:32 pm
What oil do you use with it? Do you use the same oil consistently?
Some will burn faster than others.
Postby .:O4AGTZ:. » Sun Feb 22, 2009 10:32 am
shud this not be in the tech section?
.:O4AGTZ:.
Postby matt dunn » Sun Feb 22, 2009 11:58 am
When did it last get a full oil change?
Our blacktop 20V carib uses heaps of oil when it is due for an oil change,
first 4000km will use hardly any, then use a litre in the next 1000K,and then it gets an oil change and it's right again.
