Quint wrote:When the oil cap is removed, the engine has a very hard time running and eventually stalls out.
Any one know the cause? Never seen an engine do this before.
MrOizo wrote:Its because you have a AFM.
its letting air in through the PCV in after the AFM.
BZG|Bling wrote:Can I ask why you would take the oil cap off while its running?
Quint wrote:After intake, the exhaust side has the gear on it while the IN side doesn't.
you run it without rocker covers? you one crazy b**tard!
MAGN1T wrote:The air is probably getting past the piston. Your motor's probably rooted. unless of course the PCV valve isn't hooked up properly.
On any GOOD motor it won't do this.
General PCV setup there should be a hose from the intake manifold to PCV valve. This is normally nearly closed with intake vacuum, it opens more with less intake vacuum. There's another hose from valvecover to intake piping as a vent. That allows air into the crankcase and from crankcase to intake manifold. The crankcase should always be at atmospheric pressure. With a turbo car under boost the PCV valve should fully close and the vent relieves any pressure buildup.
Steve
Steve
sergei wrote:Bollocks. Every single AE101 I have seen stalls immediately when oil cap is removed.
strx7 wrote:sergei wrote:Bollocks. Every single AE101 I have seen stalls immediately when oil cap is removed.
thats a pretty BROAD statement considering AE101's covers all the following engines 4AGE 20V, 4AF, 4AFE
MAGN1T wrote:It just goes to show how many faulty Toyotas there are then. Crankcase has to be at atmospheric pressure otherwise the oil pressure gauge will never read correctly(if you have one).
Steve
