Silvertop AE101 problems
Postby Dazed&Confused » Tue Mar 03, 2009 8:30 pm
Hi there,
trying to fix a mate of mines ae101. we cannot figure out the problem.
it is not idling smoothly, not revving to redline, the engine has no power and the engine check light is on. what could be causing this?
it happened suddenly, and he thinks it came right for a little bit when the engine check light turned off for a couple of minutes.
going to change fuel filter and check compression. any other ideas? AFM?
thanks in advance.
Dazed&Confused
Postby MR2BOY23 » Tue Mar 03, 2009 8:36 pm
I had a problem with mine- it never reved to redline. Had something to do with the ecu and afm. Had to reset codes on the ecu, as afm unplugged sent dodgy code to ecu or something
MR2BOY23
Postby rollaholic » Tue Mar 03, 2009 8:50 pm
if the check engine light is on, your first port of call should be checking the codes! i believe theres a how-to in the FAQ, or if you search it will have been detailed many a time.
with that info it should be obvious whats wrong, but it does sound like an AFM problem
Postby johndoe1025 » Tue Mar 03, 2009 10:22 pm
worst case maybe vvt, but as everyone else has said, check codes, more than likely afm
EP82 GT-went mega hard for completely stock, 15.09 quarter, gone now :(
AE111 Levin BZG current! 4AGTE next? you never know....
johndoe1025
Postby thegreatestben » Tue Mar 03, 2009 10:25 pm
Leaky caps in the ECU possibly
thegreatestben
Postby Mr Revhead » Tue Mar 03, 2009 10:30 pm
definitely check the codes
do that first
ecus are know to die on these
Postby matt dunn » Tue Mar 03, 2009 11:20 pm
My bet would be ECU.
I have a repaired one that I will either sell or do exchange on if you find out that it is that.
Postby Dazed&Confused » Sat Mar 07, 2009 11:17 am
warmed it up, shorted e1 ant te1, turned ignition on, but the c.e.l didn't flash?
Dazed&Confused
Postby RS13 » Sat Mar 07, 2009 12:47 pm
Dazed&Confused wrote:warmed it up, shorted e1 ant te1, turned ignition on, but the c.e.l didn't flash?
Try again, I had to clean the green cap off my terminals, but it should definitely flash, even if no codes stored.
RS13
Postby .:O4AGTZ:. » Sat Mar 07, 2009 5:25 pm
sounds like it went into some kind of limp mode. my gtz did that too but the cause of it was the caps in the ecu melting which i have heard is nearly a common problem. engine check light was on but no codes came up. is this a common problem on silvertops as well does anyone know?
.:O4AGTZ:.
Postby Mr Revhead » Sat Mar 07, 2009 8:08 pm
yes it is
faulty ecu running real bad and no check codes
Postby Adamal » Sat Mar 07, 2009 9:06 pm
Its probably due to the fact that the spark plugs were all busted up, and the leads so worn that they were arcing against the cam covers!
Let us know how she runs with those new leads and plugs, Lowndsy!
Postby Dazed&Confused » Sun Mar 08, 2009 7:25 pm
the leads, plugs, rotor and cap were replaced with no results. starts better however. still have engine light and wont rev past 6000.
took it for a drive, and the engine light went off and it was back to normal for about 30 seconds! it must be the ecu if it is doing this randomly?
anyway its in toyotas hands now to see if they have anything to say about it.
but we are going on the ecu being buggered. so now, has anyone got a silvertop ecu in auckland that we can try? and then buy if it fixes the problem?
oh and p.s, someone mentioned the variable valve timing could be the problem? meaning the engines dropped the pulley?
Dazed&Confused
Postby Mr Revhead » Sun Mar 08, 2009 9:09 pm
does not sound like faulty VVT to me
Postby Dazed&Confused » Mon Mar 09, 2009 8:52 am
doesnt not or does not 8O
Dazed&Confused
Postby Adamal » Mon Mar 09, 2009 11:02 am
VVT works on the oil pressure doesn't it? That'd explain why it comes right after driving for a bit, pressure comes back up. Maybe the oil pump is stuffed?
Postby Dazed&Confused » Mon Mar 09, 2009 12:39 pm
nah that couldn't be right. because when it came right it died shortly after. and we sure as hell kept oil pressure up when it came right :)
Dazed&Confused
Postby Adamal » Mon Mar 09, 2009 2:31 pm
Bro, just drop in a 3SFE from a Corona man.
Postby Mr Revhead » Mon Mar 09, 2009 7:07 pm
Dazed&Confused wrote:doesnt not or does not 8O
the latter! :lol:
