My Heater Fan doesnt work!! can anyone help??
Postby otazup » Sun Mar 08, 2009 11:49 am
hey guys i need some help,
my toyota vista (camry) 2ct diesel doesnt have a fan that works. and as its coming up to winter id be keen to sort it out
ive got the dash apart at heater side, all wires,plugs etc are connected. and ive checked fuses. one thing thats happens however is the black 5pin relay clicks when switch is turned. is this normal? and if it is just that simply mean the weak link is next in line?
i havent done voltage tests etc cause havent had tools at hand, just really wanting to know if theres a common easy fix.
thanks lads and ladettes
Jayson
otazup
Postby Lloyd » Sun Mar 08, 2009 1:58 pm
See if you have power and earth at the fan. And manually power up the fan with a good source and see if it goes. Work from there
Postby Alex B » Sun Mar 08, 2009 2:10 pm
A multimeter will cost you all of $13 from dse. :)
Postby gepsk8 » Sun Mar 08, 2009 5:36 pm
test light even cheaper from repco. all u need
O272754663
gepsk8
Postby otazup » Sun Mar 08, 2009 6:03 pm
yea gona do that but got them at work. just seeing if anyone else has experienced a similar problem in one of theirs. cheers
otazup
