No power in ae101
No power in ae101
Postby gleem » Sun Mar 08, 2009 3:06 pm
I have a ae101 gtz. The battery was relocated to the boot by last owner. Since i started working on it i have removed all aircon in engine and interior aswell as replacing the whole front loom for lights etc. All plugs etc are in. The car also has a crap alarm
Battery has 14 volts but the car wont light up or anything. if checked averything i can that i found on the net but no luck. All fuses are fine.
Could somebody suggest something
thanks
gleem
Postby Lloyd » Sun Mar 08, 2009 3:25 pm
Where does the battery power feed run to? Do any of the lights or anything at all work or have you just lost the engine side of things?
Postby gleem » Sun Mar 08, 2009 7:13 pm
ive had it runnning fine before with battery in the boot. No power at all not even to dash. Does anybody know stores were you can buy the volt detectors were you point at a wire and it beeps if powers running through but for 12v
gleem
Postby Lloyd » Sun Mar 08, 2009 10:54 pm
And where does the battery feed wire run to?? Usually hanging off the side of the positive terminal there will be a couple of fuseible links which will be the couple of fuses for basically the entire car.
Postby gleem » Tue Mar 10, 2009 7:59 pm
played around abit and soldered some wires together and now idicators etc work but no power to engine. The previous owner did a dodge job on the turbo timer and alarm. Light on turbo timer comes on but not sure if the right wires are were they are supposed to be. also the alarm and compnents dodnt work at all so this probably has something to do with it. There must be 10 odd wires from all different places going now were. Is anybody on here good with this in aucks and keen for a cashey. will be easy as theres no aircon etc in the way and its een working before so its all about connectig wires? Or wiring guieds fo ae01 if somebodys done this before?
gleem
Postby Boosted_162 » Tue Mar 10, 2009 8:02 pm
gleem wrote:Does anybody know stores were you can buy the volt detectors were you point at a wire and it beeps if powers running through but for 12v
JA Rusell does. I know Cliff got one from there (his work) to install my security cameras.
Postby gleem » Tue Mar 10, 2009 10:44 pm
ok ill look into getting one
gleem
Postby Lloyd » Tue Mar 10, 2009 10:57 pm
Lloyd wrote:Where does the battery power feed run to?
Lloyd wrote:And where does the battery feed wire run to??
