4age c52 gearbox
4age c52 gearbox
Postby Unique » Thu Mar 12, 2009 3:04 pm
hi guys recently purchased a gearbox off of crispy everything is good in it. my gearbox blew the diff up. couple of things i need to know, on the box i baught it looks like a cable drivin speedo and mine has a electrical plug in same position. is it possible to swap over? also on the reverse plug the one i have baught has a lead coming out of it to a connector as my broken box has the connector mounted in a big nut is this possible to swap over? so far have not seen any other differences but will check it out when i get home and update ne other problems. any info please comment.
also they are both c52s to my belief.
Unique
Postby AceSniper » Thu Mar 12, 2009 4:02 pm
just swap them over
AceSniper
Postby Dell'Orto » Thu Mar 12, 2009 6:59 pm
This is a tech question, not FS.
Postby Unique » Thu Mar 12, 2009 7:48 pm
yeh my bad sorry was searching thru hea and pressed post thread not realizing it.
Unique
Postby crispy'86 » Fri Mar 13, 2009 6:57 am
Yep all those bits just swap over like i said, just use the bits off your blown box onto my replacement.
crispy'86
Postby Unique » Fri Mar 13, 2009 9:32 am
cool guys. managed to get it out with some hella force. then realized some oil down the side of it will help and it slid straight out :oops: lol cheers for responses
Unique
