Gtz stuttering
Gtz stuttering
Postby TRD_ZERO » Thu Mar 12, 2009 5:27 pm
Yes i ve read the other post that are similar to this but i have specific symptoms that id like to explain first that might be able to help point out the problem quicker.
Its a facelift ae92 gtz map sensored. Drives fine and comes on boost just fine no problems. If my revs are under 3500 and i put more than 1/4 throttle it starts to stutter/miss all i have to do is back off the throttle until the revs get abit higher then im able to to increase the throttle. Sometimes if i just slowly increase the throttle it doesnt have this problem.
Previous:
TRD_ZERO
Postby themaleman » Thu Mar 12, 2009 8:59 pm
dose it happen no mater how much gas u have?
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby TRD_ZERO » Thu Mar 12, 2009 10:04 pm
yep
Previous:
TRD_ZERO
Postby levinguy » Thu Mar 12, 2009 10:10 pm
checked the conditions of the plugs and leads?
levinguy
Postby TRD_ZERO » Fri Mar 13, 2009 1:38 pm
yes i have, im wondering why it only stutters under higher load and then when revs are up its is sweet.
Previous:
TRD_ZERO
Postby 85AW20v » Fri Mar 13, 2009 5:02 pm
Checked the timing lately? Could be knocking under heavy load and your knock sensor might be working. Not as much load under light acceleration.
See ya
Simon
85 MR2 20v
85AW20v
Postby TRD_ZERO » Fri Mar 13, 2009 6:31 pm
Desnt really feel like knocking but then i havent checked the timing at all.
Previous:
TRD_ZERO
