turbo trim question(0 trim)
Postby barryogen » Mon Mar 16, 2009 2:09 pm
If someone said they had a
custom built Garrett t04e .58 a/r -0 trim with a stage 5 wheel
What the hell would that mean?
If it helps, it is on a 3.2L Golf.
barryogen
2ZZ Guru in training
Postby Jazza » Mon Mar 16, 2009 3:30 pm
PN 10657 Complete turbocharger assembly including any standard 2-3/4” diameter TO4E compressor wheel (S-3, T-5, V-1, H-3) and Hi-Fi compressor housing, N, O or P trim turbine wheel and .58, .69, .81, or .96 A/R “on-center” turbine housing
from http://fastsaab.itgo.com/t04.htm - the third site google told me.
Im assuming its an O not a 0.
1996 Curren - On Tardme
Jazza
Postby barryogen » Mon Mar 16, 2009 3:55 pm
thanks... that makes more sense than a "0" trim... was trying to figure out how the maths worked for that(was looking at equations for working out trim etc).
barryogen
Postby Phothog » Tue Mar 17, 2009 5:37 pm
N, O, P, Q Trim correspond to the sizes of the Turbine wheel
that is the Base % Exducer x some figure that garret has made up.
N Trim = 52mm Exducer
O Trim = 58mm Exducer
P Trim = 64.6mm Exducer
Q Trim = 68mm Exducer (this is really just a Turbonetics only shaft)
what he has got there is conflicting infomation
a Garrett Stg 5 Turbine wheel is about 62mm exducer
and he would only be telling half of the storey.
.58 is a turbine Air/Ratio the rest as above...
but no compressor info?
Chris.
1999 ST215W GT-T 325,000kms still going strong.
2000 M201G YRV Turbo, 1300cc little pocket rocket.
Need a Turbo Rebuilt or Upgraded... send me a email Chris @ Turbo.co.nz
Phothog
Postby strx7 » Tue Mar 17, 2009 9:15 pm
Phothog wrote:Q Trim = 68mm Exducer (this is really just a Turbonetics only shaft)
Chris.
Unless things have changed in the past few years. Turbonetics themselves dont actually make turbo parts. There is only a handfull of manufacturers worldwide who make turbo parts - compressors, turbines, housings, cores etc. Garret, Ihi, Mitsubishi, KKK and Schwitzer from memory. Companies like Turbonetics, Greddy, Trust etc Just buy turbo components from those manufacturing companies and put together the 'combination' of parts and give it a name, T67, T78, T88 etc etc.
Postby Jazza » Wed Mar 18, 2009 10:43 am
Like laptops/prebuilt mass produced desktop computers.
Compaq,toshiba etc dont build ANY of the parts, except the bit of plastic that goes around it that they name :P
Jazza
Postby steve murch » Sun Mar 22, 2009 8:14 pm
Chris.
sorry to tell you this but they do make their own turbo parts, my good mate was the president for them for 12yrs,that's also why Garrett gave them a manufacturing award
steve murch
Postby strx7 » Sun Mar 22, 2009 10:23 pm
When they first started out did they make their own???
Seems pretty odd they have the same parts (codes, sizes, names) as Garrett
Postby steve murch » Sun Mar 22, 2009 10:32 pm
strx7 wrote:When they first started out did they make their own???
if you look close they cross referance between them and garrett, they also have differant shaft sizes to garrett in differant models as with there bb stuff to which you have to get from them as garrett doesnt make.
turbonetics turbine hsg weigh twice that of garrett and arnt finished off very well.
also the comp wheel tip hieghts can be different, and the comp covers are their own.
just like master power and afew others they all copy garrett yet garrett is far from the best you can buy
steve murch
Postby rollaholic » Mon Mar 23, 2009 9:37 am
what would be the best you can buy? out of interest.
and what about HKS? i know they charge the earth for alot of their stuff, but i thought the whole point of their products was that they were developed and built in house, so to speak
Postby steve murch » Mon Mar 23, 2009 10:26 am
rollaholic wrote:what would be the best you can buy? out of interest.
HKS is made by garrett they dont touch them as far as manufacturing goes just put the name on it.
whats the best? how deeps your pocket is what it comes down to and the more turbo you run the more motor you need so its a double edge sword.
what i think is the best is from what ive seen over 20yrs of doing this and each turbo has its own merit.
garrett is very comon and thats why most copy it but the real good stuff isnt as easy to copy and when you do you find out why they cost so much.
for the most your wallet tells you what your going to buy.
steve murch
Postby strx7 » Mon Mar 23, 2009 12:41 pm
Best bet for a turbo is to go and talk to Steve in person and see what he suggests and get him to build you one to suit your engines needs/requirements. Have done this on all my competition engines and have yet to have something which wasn't ideal.
Postby rollaholic » Mon Mar 23, 2009 4:49 pm
im not in the market for a turbo, i was just interested to hear his opinion as one of the most well regarded turbo gurus out there.
(im still interested to know by the way :P)
Postby steve murch » Mon Mar 23, 2009 5:52 pm
rollaholic wrote:im not in the market for a turbo, i was just interested to hear his opinion as one of the most well regarded turbo gurus out there.
know which bit? whats the best?
this could on for a long time if i covered what ive found over the years,lol
steve murch
Postby rollaholic » Mon Mar 23, 2009 9:14 pm
i suppose theres as many 'best' turbos as there is engines. i guess what i was really meaning was - is there a manufacturer that stands out to those 'in the trade' like snap-on does when it comes to tools... that is, most people dont see the value in paying 5-10x as much for a tool that does the same job, but people who use them every day can see the benefits.
or to put it another way, when you want the best, and money is no object you buy XYZ turbo
Postby steve murch » Mon Mar 23, 2009 9:30 pm
rollaholic wrote:i suppose theres as many 'best' turbos as there is engines. i guess what i was really meaning was - is there a manufacturer that stands out to those 'in the trade' like snap-on does when it comes to tools... that is, most people dont see the value in paying 5-10x as much for a tool that does the same job, but people who use them every day can see the benefits.
i would say ihi for out right quality but they all have their plus/minus depending on what your after and backup for parts,your wallet etc.
i could go on but i normally bore the crap out of people,lol
steve murch
Postby finx » Tue Mar 24, 2009 10:08 pm
blather away steve this is all interesting stuff!
behind almost every good import (note: almost) there's turbo. but theres not that many people that know as much about what goes into them and how that can change the overall outcome, compaired to the rest of the works that go on in the build. myself included.
daily: ep71 turbo s 2et 90hp atw 15.5sec 0-400m (stock) current 5efhte + ct9b on 6psi, 13.7@158km , torque steer??
nothing sounds like a 2stroke engine on the rev limiter
finx
Postby steve murch » Tue Mar 24, 2009 10:57 pm
finx wrote:blather away steve this is all interesting stuff!
proboly this is one of the hardest things i can do is to relay on the info ive gathered in the past 20yrs.
but im working towards something that should help all but its alot of work
steve murch
Postby cat007 » Wed Mar 25, 2009 8:46 am
Also weren't Toyota, for a while there, the only manufacturer to make their own turbos?
Postby steve murch » Wed Mar 25, 2009 7:30 pm
that sounds about right, unfortunatly these days im unsure whos making what for who.
cutting corners in many ways is a sign of the times for alot to keep heads above water, i would still rather pay extra to get quaility and it doesnt take much more to do so.
but i guess when your making thousand of parts then 10c increase per item adds up.
steve murch
