SW20 Electric Antenna Problem
Postby MR2BOY23 » Wed Mar 18, 2009 8:07 pm
Has anyone ever had a problem with the standard mr2 electric antenna before? Mine doesnt go up when the radio is on. Im sure its getting power as it is plugged in, do the motors seize or something on these? or do the masts sometimes need replacing? Thanks alot
MR2BOY23
Postby Mr Revhead » Thu Mar 19, 2009 10:58 am
yep they often fail
either (the most common) the toothed nylon belt they use to move the pole up or down has broken or (almost as common) the motor has failed
Users browsing this forum: Bing [Bot], Google [Bot] and 14 guests
