how far can you build a 4age with stock ecu
Postby LOWDWN » Thu Mar 19, 2009 9:41 pm
how far performance wise can i go before i have to up upgrade ecu
4age smallport in ae92
or whats my best bet on building the engine
would the ecu run head skim port/polish and adj cam gears and prob fuel reg or injectors?
thnaks guys
sam
021-0290-7728
LOWDWN
Postby bluemaumau » Thu Mar 19, 2009 10:05 pm
the best option is an aftermarket ecu
but yes it should run all that stuff, depending on specs.
but i dont think youd need bigger injectors on a n/a 4age
youd need cams to take real advantage of any other head work
Postby LOWDWN » Thu Mar 19, 2009 10:13 pm
mint, yea if i could find some at the time id get them
but then its all over for the stock ecu idea correct?
want to get it going on a budget with out cutting corners and regreting later on, so i can finish geting power later on
021-0290-7728
LOWDWN
Postby d1 mule » Thu Mar 19, 2009 11:21 pm
ECU man, i had 100 WHP out of a blue top with extractors filter and a link G1 V5 and avgas 8) went bloody goot for a wee motor
d1 mule
Postby rollaholic » Fri Mar 20, 2009 1:26 pm
get some ARP headstuds so you can remove the head more freely and get it running as relatively stock. then you can add cams / headwork as desired / money allows
Postby LOWDWN » Fri Mar 20, 2009 6:01 pm
rollaholic wrote:get some ARP headstuds so you can remove the head more freely and get it running as relatively stock. then you can add cams / headwork as desired / money allows
i like this idea, apart from a brand, whats diff about the arp headstuds, and do you get a metal headgasket?
021-0290-7728
LOWDWN
Postby rollaholic » Fri Mar 20, 2009 6:31 pm
headstuds are like the shaft section of a bolt, but they stick up out of the block and you lower the head down onto them, then add a nut to torque the head down.
the idea is they are re-usable multiple times, whereas your standard headbolt should only be used once (though many people re-use them) so they work out cheaper if you intend to take the head off multiple times to fiddle with things.
you could use whatever headgasket you liked, but i couldnt comment on their re-usability as i've never tried it myself :D
Postby LOWDWN » Fri Mar 20, 2009 8:34 pm
haha cool, i know what the headstuds are lol just not wat the arp ones had advantage of,
yeap fair point tho spose a headgasket aint worth much, not worth the risk
cheers!
sam
021-0290-7728
LOWDWN
