ST185 Close Ratio G/Box > Non CR-Rear Diff Change Needed?
Postby KE25-KP30 » Thu Mar 26, 2009 11:57 pm
Hey guys, I've got a ST185 GT-Four Rally, which is a narrow body version made for rallying (funny enough!). It came with the close ratio E152F which is sadly not in a good state (graunch into 2nd, won't go into 3rd) so I've pulled it out, and have a stock GT-Four box to go in.
The question is, do I need to look into changing the rear diff to match, or are the front diffs the same on all the GT-Four/ E15*'s which in turn will mean no change needed?
Also, has anyone here done a gearbox overhaul in a garage (i.e DIY)? How difficult and what are syncro's etc worth?
Thanks a tonne!
KE25-KP30
Postby RunningRich » Fri Mar 27, 2009 12:23 am
Every GT-Four uses the same rear diff ratio therefore all the gearboxes are interchangeable.
Have a read of the manual regarding rebuilding. A lot of specialised pullers are needed on this box.
Alfa boxes are very different, apart from the bolts you can literally disassemble them with a hammer, a punch and a pair of pipegrips. :lol:
Richard
http://gtfour.supras.org.nz
RunningRich
Postby strx7 » Fri Mar 27, 2009 6:50 am
synchro's are usually $200-300 each
Postby KE25-KP30 » Fri Mar 27, 2009 8:47 am
Awesome, thanks for that! Yeah I can imagine that they would be a mission.
Ouch, does that mean that parts alone are going to be around the grand mark?
Thanks again :D
KE25-KP30
Postby TRD Man » Fri Mar 27, 2009 9:37 am
Running Rich is correct. Final drives are the same.
The gearbox is worth fixing. The ratios 1st through 4th are quite different from a regular GT4 and you'll really notice it.
TRD Man
Postby KE25-KP30 » Fri Mar 27, 2009 3:30 pm
Oh really - I did wonder if that was the case, and reading around seems they are slightly rare. Maybe I'll save it for a rainy day!
On another note, if it wouldn't go into third when the car was running, does that point to a shot syncro, or worse?
KE25-KP30
Postby strx7 » Fri Mar 27, 2009 3:51 pm
synchros are probably cracked so when the cluster is rotating they expand, like trying 12 groove into a 13 groove hole.
when we rebuilt my rx7 gearbox it was like that, it would hardly ever go into 3rd and it was cracked right thru in one place and nearly thru in about 6 others
and yes that estimation is PER synchro. Toyota synchros are pretty pricey. Rebuilt my bosses landcruiser box at work here and new synchros were over a grand.
Postby Boosted_162 » Fri Mar 27, 2009 6:15 pm
If your keen on selling it....im keen!! :D :D :D
Postby RedMist » Sat Mar 28, 2009 8:54 pm
I'd read reviews on the box and a majority of those who use them on the road want rid of them. On paper they look a little weird as well with a short 4 cluster then a big jump to 5th. I would think they work well for what they were designed for... rallying.
Isn't the 152 part of the generation of ST165/185 boxes that had weak synchro's and hence the switch to a tripple synchro in the 205?
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby KE25-KP30 » Sat Mar 28, 2009 11:36 pm
Thanks strx7, makes sense!
I wondered if you might say that Boosted_162 - I'll keep you in mind if and when!
Interesting what you say RedMist - when you say rallying, would that "umbrella" general track racing too... I guess you would use gears 1-4 around a track, and the theory is that on the open road it would be like any other and not reving it's head off. I've also read along the lines of the weak syncros... I guess that's why 2nd and 3rd are no go in mine!
Cheers for the replies/input :)
KE25-KP30
Postby Prymal » Sun Mar 29, 2009 12:16 pm
have a looksee around for a 205 box , and shelve the close ration one in the shed and piece t back together when you can
you could find a runner 205 box , for the price of rebuilding the one you have - And it will be stronger.
Prymal
Postby KE25-KP30 » Sun Mar 29, 2009 2:16 pm
I've got a stock 185 box for the time being, but a 205 would be ideal. Aside from the syncros, are they much different to a 185 box? i.e stronger in general?
KE25-KP30
Postby Prymal » Mon Mar 30, 2009 9:34 pm
bigger transfer case ( from memory ) no FWD limp mode selector - better syncro's , different gear rations , basically unbreakable unless your an idiot or race/thrash them
Prymal
Postby Twolitre » Tue Mar 31, 2009 8:28 pm
Do you know the history of the ST185 box you are going to install into your celica? It could be just as bad as the one you're currently using and it would suck to go to all that effort for no gain.
An ST205 box would be ideal but they aren't cheap or easy to find and you could probably rebuild your close ratio box for the price of a 2nd hand ST205 box.
Twolitre
Postby Prymal » Wed Apr 01, 2009 6:06 pm
that depends on the syncro set used ..
the St205 ones and RC ones arent exactly Cheap .....
Prymal
Postby KE25-KP30 » Thu Apr 02, 2009 5:01 pm
Wow, didn't realise the 205 boxes are that tough!
No ideas on the history of the box and definately good point, but I'm going to take the chance on it anyway and so long as it's drivable I can look for another one or rebuild the CR box.
When you all say a 205 box isn't cheap... what sorta money are we talking?
KE25-KP30
Postby DeeCee » Thu Apr 02, 2009 5:59 pm
st205 box ranges between $300 - 1000 or more. Very rare to see a st205 around the $300 mark or below and commonly are seen on TM at the $1k mark.
GT Four Adovansu
DeeCee
Postby KE25-KP30 » Thu Apr 02, 2009 6:58 pm
Ouch! Thanks - I'll start to keep my eyes open for one.
KE25-KP30
Postby sergei » Thu Apr 02, 2009 10:23 pm
I have imported complete st205 gearbox (including transfer case) and rear diff for $750 from japan (all done about 50k), shipping was free as I just asked them to put in one of the cars that the company I worked for bought.
