DXROLLA wrote:Cheers for the help, i had used the search function but couldnt find anything specific to what i was after.
So a standard re-build should be suitible and will handle the power i am looking for? Just need a good tune and some injectors?
Mr Revhead wrote:http://forums.toyspeed.org.nz/viewtopic.php?t=58213
DXROLLA wrote:Sweet cheers for that so the ze pistons will be fine to go on my rods 20mm red top ones?
DXROLLA wrote:Yeah those prices do look very good, mite get me a set of them. Do you think itl be worth using some ARP bolts maybe head studs atleast?
Whats the main advantage over the 8.9:1 piston to the 8.0:1? Im guesing you could make more power with the 8.9:1 with the slightly higher compresion? Would that effect how much boost you could run?
Mr Revhead wrote:just remember that 4agze pistons are forged and well up to 200hp
gleem wrote:whats the most hp you can make on a stock ae101 ze bottom end for reliability?
