BZG|Bling wrote:I thought the level was determined by the filler hole on the front... or was it back I can't remember.
But from what I recall, its full when it starts to pour out of the filler hole. Do a search though as its been covered I just can't remember the exact procedure.
xsspeed wrote:assuming you fill it in the side hole you will probably have trouble overfilling it, as when it gets up to the correct level it will start leaking back out the hole you are trying to fill it in.
