How does the 4-AGE 20V stand up to mileage?
Postby Kittah » Mon Apr 20, 2009 4:24 pm
Hey guys,
I've been offered a swap for my S13 Silvia, for an AE111 Levin BZ-V and I'm sorely tempted. The only thing holding me back is that it's travelled something like 206,000km. What can I reasonably expect from an engine that's travelled that far, generally speaking?
I know it's pretty vague and depends highly on how it's been treated, but what are your thoughts when the idea of a 200,000km AE111 BZ-V enters your mind?
Cheers :)
Kittah
Postby thornz » Mon Apr 20, 2009 4:32 pm
200kms is nothing, the engines probably only just been run in.. :lol:
thornz
Postby Sh0ckwave » Mon Apr 20, 2009 4:37 pm
My silvertop had done 210,000
Its got slow oil leak somewhere, burns a bit of oil if driven hard, and the VVT pulleys are rattling a bit.
But apart from that it runs perfectly
Sh0ckwave
Postby xsspeed » Mon Apr 20, 2009 4:40 pm
thornz wrote:200kms is nothing, the engines probably only just been run in.. :lol:
For truth
Postby TRD_ZERO » Mon Apr 20, 2009 5:08 pm
The bz-v is the best out of the ae111 and arnt that common, whats the rest of the condition of the car like? Any other extra goodies?
Previous:
TRD_ZERO
Postby jakesae101 » Mon Apr 20, 2009 5:08 pm
my silvertop had done 287000ks and it was fine my 4agze has done 260,000ks and still going strong
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby RS13 » Mon Apr 20, 2009 6:09 pm
I'd check under the cam covers as per viewtopic.php?t=72435. Other than that, if its' reasonably quiet and doesn't blow much oil smoke then it would likely have been looked after. My car has done 180,000km on its' silvertop, uses minimal oil between changes, as was said VVT pulley is a little rattley but its' awesome otherwise.
Get an AA check if you're worried.
RS13
Postby Kittah » Mon Apr 20, 2009 11:58 pm
RS13 wrote:I'd check under the cam covers as per viewtopic.php?t=72435.
Presumably that's the sort of thing I can get an idea of by shining a light under the oil filler cap. Cheers for that heads-up, though I like to hope that kind of build up is a rare occurrence :lol:
Definitely. Hoping I can book a check and organise a test drive for the same day.
Anything anyone can advise me of in terms of things to look out for when buying an AE111? :)
Kittah
Postby sergei » Tue Apr 21, 2009 12:18 am
AA people don't do real compression tests.
Not that is important as it is easy to spot low compression symptoms on a car without doing compression test (it is good as confirmation)
Postby neo » Tue Apr 21, 2009 9:56 am
most 20v's I've seen have been rebuilt by 200k, best I've seen is 440k odd but that engine was wasted.
Were talking about highly thrashed 4 banger cars here, not trucks.
See a stone cold start-up / watch for puffs of smoke out the back, new engines shouldnt do it, older 20v do. -confirm with a compression test (remember to remove the ecu fuse!)
VVT pulley will most likely be poked by 200k making the engine sound like a truck.
Then again, it may have been owned by a grandma, who had it serviced with synthetic oil every 4k.
neo
Postby slighty_sykotic » Tue Apr 21, 2009 10:09 am
Mrs's 20v just clicked over 335,000kms the other day.
Honestly it is getting a little tired in terms of oil usage, but runs flawlessly, never misses a beat.
And it still gets driven hard every now and then when i'm driving :twisted:
As they said above, as long as its been looked after 200km is nothing at all
slighty_sykotic
Postby Dell'Orto » Tue Apr 21, 2009 12:46 pm
Definately, the wife's old AE101 was nearing 200k's when she sold it and it was still running like a dream. Aside from ye olde VVT rattle of happiness.
Though I've seen blacktops die much much earlier than any silvertop, so it is a bit of a lottery really.
Postby Mr Revhead » Tue Apr 21, 2009 2:39 pm
[quote="neo"]I've seen is 440k odd but that engine was wasted.
quote]
rubbish! its running fine! :twisted:
Postby neo » Tue Apr 21, 2009 4:45 pm
Mr Revhead wrote:
neo wrote:I've seen is 440k odd but that engine was wasted.
If you call 1st gear up the gorge + using as much oil as petrol.. YIP!
neo
Postby Kittah » Wed Apr 22, 2009 12:11 am
Haha cheers everyone, you've given me something to be optimistic about :)
TRD_ZERO wrote:The bz-v is the best out of the ae111 and arnt that common, whats the rest of the condition of the car like? Any other extra goodies?
Why is the BZ-V the best of them?
The rest of the car is apparently in good nick; seller took it for a warrant today and said it flew through, and that the mechanic was confident of its condition. He said the cambelt and VVT belt have been done recently, and the super strut was done some 18 months ago, so it's all sounding all right.
I'm planning to organise a chance to go and have a look at it and get a vehicle inspection done, and to take it for a test drive. Pity it's about two hours' drive away, but that's part of the price you pay 8)
Kittah
Postby Dell'Orto » Wed Apr 22, 2009 12:35 am
Kittah wrote:He said the cambelt and VVT belt have been done recently,
VVT pulley is on the cam sprocket, they dont run a seperate belt like a balance shaft :lol:
I have to ask - whats wrong with your S13 if you're swapping it for an AE111? Or is there cash involved too?
Postby Kittah » Wed Apr 22, 2009 1:13 am
Dell'Orto wrote:VVT pulley is on the cam sprocket, they dont run a seperate belt like a balance shaft :lol:
His words, not mine - I'm not used to fancy VVT things with an S13 :P
It's in amazing condition, probably one of the best largely-original S13s in the country, but...
...it's automatic :lol:
I'm at university now studying law, and I just don't have the money to put towards the manual conversion, alas.
Kittah
Postby Boost_4_Life » Wed Apr 22, 2009 8:38 am
that really does sounds like my old levin? is it in hamilton, number plate BCM454?
The rally beast
The rally beast again!
Boost_4_Life
Postby B1NZ » Wed Apr 22, 2009 8:45 am
Boost_4_Life wrote:that really does sounds like my old levin? is it in hamilton, number plate BCM454?
Also sound like my old one which is up that way, Is plate AWA475?
Mine was rebuilt at about 170000km's due to excessive oil burnage
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Boost_4_Life » Wed Apr 22, 2009 8:47 am
i miss my BZ-V. But my oil bill like yours, is certainly a lot cheaper :lol:
The rally beast
Boost_4_Life
