Whats The Worst That Can Happen At High RPM?
Postby celica_xr9145 » Mon Apr 20, 2009 11:08 pm
Well, i was on the way home today and to get there i got to up a steap hill for about half a kilometre, when i drive up there i have no choise but to stay in second gear at around 4500rpm and sometimes higher. I try to shift into 3rd but loses power and have to go back down to second.
Basically, whats the worst that can happen if i stay at high rpm in second gear? Im sure its not ok for the car.
Is there any maintenence i can do to give it a bit more grunt?
Ive driven a 1.6 ford escort with half the power and it gets in 3rd no problem 8O
celica_xr9145
Postby RomanV » Mon Apr 20, 2009 11:14 pm
Assuming you're talking about your celica?
You havent even hit peak torque for that motor at those rpms, and you're still a long way from peak horsepower...
In other words, you're not yet even in the rpm range which the engine was built to do well in.
Go nuts.
Second gear should get you pretty close to 100kph :P
P.S. Bogging the motor and putting heaps of load on it at low rpm can be just as bad, or worse than revving it out a bit. What sort of fuel are you running it on?
Postby celica_xr9145 » Mon Apr 20, 2009 11:17 pm
RomanV wrote:Assuming you're talking about a gen 2 3SGE?
you havent even hit peak torque for that motor at those rpms, and you're still a long way from peak horsepower...
Go nuts.
Really, wasnt expecting that, lol.
Just doesnt sound healthy but does sound nice 8)
celica_xr9145
Postby celica_xr9145 » Mon Apr 20, 2009 11:18 pm
i always use premium fuel, i find that using normal make my tappets loud and loses power on acceleration
celica_xr9145
Postby Jazza » Mon Apr 20, 2009 11:29 pm
I hit 85 at approx 5500 RPM in 2nd in my curren, with a smaller, less powerful engine than your sillycar.
If you look at your dash.. see the needle with numbers 1000-6500... dont let the needle stay in that red part for too long and youll be fine :lol: :lol:
1996 Curren - On Tardme
Jazza
Postby evil_si » Mon Apr 20, 2009 11:30 pm
4500 isnt high rpm
evil_si
Postby celica_xr9145 » Mon Apr 20, 2009 11:49 pm
Jazza wrote:I hit 85 at approx 5500 RPM in 2nd in my curren, with a smaller, less powerful engine than your sillycar.
85, wow, didnt know they were capable of that, lol 8O
celica_xr9145
Postby celica_xr9145 » Mon Apr 20, 2009 11:53 pm
evil_si wrote:4500 isnt high rpm
is it not, i thought for a car thats 20 years old, 4500rpm was considered high, lol, the last thing i need is a new engine :lol:
celica_xr9145
Postby thegreatestben » Tue Apr 21, 2009 12:03 am
20 years ago wasn't 40 years ago.
Give it death!
thegreatestben
Postby Jazza » Tue Apr 21, 2009 12:03 am
As long as the car is warm, and has had a relatively well cared for life, it shouldnt be a problem. My civic tends to sit close to 4500 - 5500 RPM most of the way around the thames cost and hills, because thats where i get the best response when i stick my foot down.
Jazza
Postby Bling » Tue Apr 21, 2009 12:04 am
4500 in a van is high, not in a 'sports car'
Just make sure you have oil inside and it shouldn't care about those revs. 8000rpm is high :wink:
In regards to the escort engine being able to do the hill in 3rd, the engine is different, the gearbox is different and the diff can also determine how fast its actually going at any given rpm. Whats ya rev limit?
Man up and do it in 1st*
*may cause engine to die a horrible death
Postby sergei » Tue Apr 21, 2009 12:17 am
9000rpm is high :)
well as long as you are not sitting on rev limiter prolonged times you will be fine (providing there is oil in the motor).
I assume you have 3SGE (red starts at 7ish)?
If it is 3SGE then it even hasn't started to really pull at 4500rpm.
Postby celica_xr9145 » Tue Apr 21, 2009 12:19 am
BZG|Bling wrote:4500 in a van is high, not in a 'sports car'
The rev limit is 7000rpm i think
http://memimage.cardomain.com/ride_imag ... _large.jpg
I might start bringing those revs higher and see what this car can really do now i know it will be ok :) :)
As for going up in 1st, not a bad idea, lol :lol: :lol: :lol: :lol:
celica_xr9145
Postby celica_xr9145 » Tue Apr 21, 2009 12:21 am
sergei wrote:9000rpm is high :)
yep, its the gen 2 3sge as romanv said, better go out and check the oil.
Cant wait to see what these engines can really do :D
celica_xr9145
Postby Bling » Tue Apr 21, 2009 1:10 am
celica_xr9145 wrote:Cant wait to see what these engines can really do :D
Don't get your hopes up too high :lol:
Postby celica_xr9145 » Tue Apr 21, 2009 1:12 am
:lol: :lol: lol :lol: :lol:
celica_xr9145
Postby Jazza » Tue Apr 21, 2009 2:31 am
Keep her soft and sweet in first, then let loose in 2nd and third... my car hates traction in first gear :( But definately give her some shit... :lol: 8)
Jazza
Postby GDII » Tue Apr 21, 2009 9:53 am
My 1990 MR2 doesn't see over 6k rpm as the power drops off, may be due to the dodgy cat back exhaust.
4500rpm isn't high. Try running 98 octane.
What road you driving up? My car pulls up most of Dunedins steeper streets no problem in 3rd.
But I guess there may be some difference in final drive and car weight between MR2 and Celica.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby l1ttle_d3vil » Tue Apr 21, 2009 9:56 am
4age engines are 20 years old, the TVIS on them only opens at 4500 to give them more grunt - and it stays open to 7000+ rpm :wink:
Postby celica_xr9145 » Tue Apr 21, 2009 10:47 pm
GDII wrote:My 1990 MR2 doesn't see over 6k rpm as the power drops off, may be due to the dodgy cat back exhaust.
it mainly happens up every street in andersons bay, the car is in need of an oil change as im told the oil is dirty, hopefully it will make a little difference 8)
celica_xr9145
Users browsing this forum: Google [Bot] and 19 guests
