Stronger diff needed
Postby CelicaGT8 » Wed Apr 22, 2009 12:43 am
Celica gt4 - 1uz
Ok, so im needing to put my rear end in, but first i need to do something about the diff.
The standard diff wont handel a 3sgte in rwd let alone the 1uz,
so does anyone no of different internals i can use? prefer lsd
Or
What diff would be recomended as a replacement?
Needs to be reasomly cheap, and easy to replace the old diff
CelicaGT8
Postby strx7 » Wed Apr 22, 2009 9:14 am
if its only going to be RWD then i'd say you'll need a G series IRS diff head outta a Cressida/Supra/Chaser etc etc if 4wd you MAY get away with an F series IRS from an altezza or similar
Re: Stronger diff needed
Postby cat007 » Wed Apr 22, 2009 9:26 am
CelicaGT8 wrote:Celica gt4 - 1uz
Or
I have a 4.5:1 open G series....I think it's a 4.5:1....
Postby Prymal » Wed Apr 22, 2009 11:30 pm
justen's Gt8 ran a standard rear , killed it pretty quick with a forced 1uz ..
he now rums a JZA70 rear end in it modified to fit in the gt4 cradle ..
its holding - but is running an aftermarket LSD ..
Its only weak point is the small gt4 hub barriers i believe - though last note was he was investigaring getting these changed ro jza70 or 80 spec
Prymal
Postby CelicaGT8 » Wed Apr 22, 2009 11:45 pm
Im going to use the standard rear cradel aswell, the gt4 hub barriers are the least of my probs at the moment...
Im just staying NA atm, and rwd
Isnt there a 3.9to1 G series diff?
Would you recon that would be the best to run with?
And it sounds like G series is the one to stick with, does anyone have one to sell, even if it isnt the preferd ratio, it could still be used as a mock up which is what im needing atm
CelicaGT8
Users browsing this forum: Google [Bot] and 26 guests
