xsspeed wrote:Celica 3sge will be beams if from a SSIII model
sergei wrote:strx7 wrote:I am comparing 3rd gen 3SGE non VVTi against Altezza 3SGE dual VVTi
Non VVTi vs VVTi are completely different heads (that includes combustion chamber).
Mr Revhead wrote:arnt the pin heights different?
Celica RA45 wrote:gen 3 has dome pistons and a wider valve angle for 10.4 to 1 comp
altezza has a tighter valve angle and taller head auto motors are 11to 1 manual altezza 11.5 to 1 comp
easy way to see gen 3 cam pulleys are 25 mm apart
altezza 5mm apart and cumbustion chamber is 33cc
gen 3 is 60cc or there abouts
crank same, rod length same, bore and stroke same ,
Celica RA45 wrote:that 10.4 to 1 looks like my 13.5 to 1 piston that i use in my race beams motor ,but also i have 8mm deep valve fly cuts for vvti still as well
KinLoud wrote:I have several sets of 3sge and 3sgte pistons including a set of (what I think is) gen3 3sge pistons. Let me know if you want any.
Ken
Auck
021 408 863
