fuel pressure???
fuel pressure???
Postby tim_blair » Thu Apr 23, 2009 9:47 pm
i have i black top 4age and i have installed an aftermarket fuel pressure regulator what pressure should it be running at??
tim_blair
Postby Mr Revhead » Thu Apr 23, 2009 10:15 pm
why did you do that?
viewtopic.php?t=71839
in htere you will find the manual, in that you should find the stock info
Postby NZ_AE86 » Fri Apr 24, 2009 8:20 pm
Why did you do that 2?
Well you should set it to the factory specs or you could just let Mr Toyota worry about it for you!
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby CelicaGT8 » Fri Apr 24, 2009 8:55 pm
Why did you do that 3?
Haha, just felt left out.
its always fun to put smthing shiny in your engine bay
CelicaGT8
Postby NZ_AE86 » Sat Apr 25, 2009 10:46 am
True, each to their own.
Current rides;
1986 Levin GT
NZ_AE86
Postby bs » Sat Apr 25, 2009 11:05 am
bs
Postby NZ_AE86 » Sat Apr 25, 2009 11:14 am
He would make the perfect customer - only gives half the info and somehow expects the correct answer!
Current rides;
1986 Levin GT
NZ_AE86
Postby tim_blair » Sat Apr 25, 2009 11:16 am
yes i like shiny things
and also yes i think itl help with my supercharger project which is comeing along quite nicely
i looked at 1 of thoes pdf files but couldnt find it
what harm could an aftermarket fpr do if the pressure is the same
i have it at about 40psi and its running good but id like to have it at the standed pressure
tim_blair
Postby sergei » Sat Apr 25, 2009 11:29 am
It could be funky ratio one, "rising rate". Makes car run rich on low vacuum.
Postby Mr Revhead » Sat Apr 25, 2009 2:23 pm
yeah reason i questioned is no info givem, if it stock, why fit one?
if not, whats been done as that would affect the answer
im sure the stock fuel pressure will be in that manual
Postby frost » Sun Apr 26, 2009 1:08 am
37-42psi.
Postby tim_blair » Mon Apr 27, 2009 7:08 pm
found
34-40 psi thanks alot thoes manuals are good
tim_blair
Users browsing this forum: Google [Bot] and 26 guests
