20v headgasket
20v headgasket
Postby lee90 » Wed Apr 29, 2009 9:11 am
can carbon headgasket uncompressed measure...1.35mm fit for NA?
info
gidday...p/n 2116KC will suit 91 to 2000 years according to there web site....permaseal. 4AGE engines. still tryin to identify its thickness for you....its got 524 marked on it
lee90
Postby Dell'Orto » Wed Apr 29, 2009 11:32 am
That sounds roughly right, they compress down a bit when fully torqued. Why use a Permaseal one though when a TRD one is around the same price?
Postby lee90 » Wed Apr 29, 2009 1:28 pm
dus it matter about the mm because the TRD is 0.8mm thick.
i just wonder if this can fit in my NA motor.
lee90
Postby Bazda » Wed Apr 29, 2009 2:38 pm
Why do you want to put one on...
You are going to raise the compression, therefore need a retune, therefore need a programmable ECU.
Postby Mr Revhead » Wed Apr 29, 2009 6:54 pm
hmmm isnt stock thickness 1.2mm? in which case you will be lowering it....
use the TRD one, works well and is proven
Postby BZR4AGE » Wed Apr 29, 2009 7:11 pm
Lee...i thought I told you before man.
the thicker the gasket, the lower the compression.
the thinner the gasket, the higher the compression.
And if you want to go turbo, go for the thicker one
If you want to go NA, go for the thinner one
And did you get a hold of 1I1 our Toyota Sponsor? I am sure they can do it cheap!
BZR4AGE
Postby .samol. » Thu Apr 30, 2009 11:55 am
How much re the TRD ones? Worth it for a non worked or tuned 4awg?
.samol.
Postby crispy'86 » Thu Apr 30, 2009 1:46 pm
refer to our sponsors section for the contact people for prices. As for just fitting the head gasket, i noticed a big improvement with my engine running the trd 0.8mm gasket, my 16v 4age engine went well before i pulled it apart to freshen it up, went even better after fitting the trd gasket., You'll need to run minimum 95 octane fuel, probably better to use 98 to gain full benefit from it. You'll also need to change your ignition timing to suit as even if 3 degrees the wrong way (advanced or retarded) it may pink. Those are the symptoms of my engine and, it may have had a bit taken off the head previous to me owning it, i can't be 100% sure
crispy'86
