3sge
3sge
Postby petrolhead » Sat May 02, 2009 4:41 pm
does any one know if you can use gen 2 3sge pistons in a gen1? i understsnd en1 is non interferance so would this raise compression. what other bits could be swapped out from gen 2 to gen 1?
petrolhead
Postby CelicaGT8 » Sat May 02, 2009 8:34 pm
You can swap most things, iv used 2nd gen pistons in the 1st gen motor,
Infact nz new 1st gen 3sge's used hi comp pistons from factory, you could prob get some of those.
CelicaGT8
Users browsing this forum: Google [Bot] and 20 guests
