Ae85/6 front adjustables, cert
Postby rx7guy » Sun May 03, 2009 2:58 pm
Hi I've got an ae85 with d2 adjustables. At a low ride height the front springs are not captive. I will be going for a cert once I've got a bunch of other things fixed.
Do the springs need to be captive for all possible ride heights?
What would be the better option to make them captive? Keeper spring or shorten the strut?
Thanks, Aidan
The torque band is wide and the road is narrow
rx7guy
Postby shihad » Sun May 03, 2009 3:09 pm
no i dont think they have to be captive at all heights when you get ur cert plate it will state the height of you car and you get a 5% tolerance i think so set it 2 the height you want 1st as i dont think your aloud to change it.keeper springs rock i definitely recommend them.
getting bottled by the friendly Oamaru locals for not doing skids - Coupe Life
shihad
Postby Lloyd » Sun May 03, 2009 3:44 pm
And they seem to be bloody expensive for what they are too. But as said, you'll have a set ride height that it should be set at so if they're captive at that then you should be fine
Postby rx7guy » Sun May 03, 2009 4:59 pm
Ok sweet. I'll have to find some keepers then.
rx7guy
Postby d1 mule » Mon May 04, 2009 10:37 pm
best option is to hiff the shocks that caome with the kit on trade me and get some adjustable konis that are actually the proper length.stroke as the D2 shocks are standard length so when slammed the shocks are bottomed out.
i had to raise my old z10 soarer with ae86 K sports (same as D2) by like 25mm when went for cert cuz the shocks were bottomed out
d1 mule
Postby Mr Revhead » Mon May 04, 2009 11:06 pm
yeah.....
helper springs are a mad price!
if possible design the suspension so you dont need them! to save some coin
Postby rx7guy » Mon May 04, 2009 11:09 pm
You know these are your old shocks aye d1mule. I'm spending heaps on it already, im running out of cash so dont think ill be getting konis, maybe later.
Why not just get the shocks shortened if they are too long? Is it a bit rangi or what?
rx7guy
Postby Mr Revhead » Mon May 04, 2009 11:11 pm
if they have been run bottomed out they maybe stuffed anyway
i doubt you could shorten them, isnt the adjustment done from the top?
you would have to get new inserts
Postby rx7guy » Mon May 04, 2009 11:15 pm
They still seem to be firm, I might take them out and see how far they go before bottoming out.
rx7guy
Postby shihad » Tue May 05, 2009 4:20 pm
there might be some 2nd hand keepers floating round on garagedori check that out. brand new 500 i was quoted got them 170 2nd hand was stoked.
http://www.trademe.co.nz/Trade-Me-Motor ... 169640.htm
no idea if this is useful???
shihad
Postby Mr Revhead » Tue May 05, 2009 6:58 pm
500 new?! where were those rapists?
i think we do them for about $60-70 each
but done forget you will also need keeper seats
Postby shihad » Tue May 05, 2009 7:02 pm
lol mag n turbo warhouse yea 170 got me seats as well
shihad
Postby d1 mule » Tue May 05, 2009 7:25 pm
really??, i never sorted the shocks out before i sold the car, i left them in the car Z10 and im fairly sure they are still in it... weird???
did you get them through simon??? may be my old fltamate richards ones
d1 mule
