1ggte issues.
1ggte issues.
Postby trdtrueno » Thu May 07, 2009 10:14 am
Hi guys, noticed a few things while driving my GA70 supra around, only started using it alot more recently so only just noticed these things....
ok, after the car has warmed up and i have been driving for a little while and come to a stop, the revs will drop below 1000 and stall...only sometimes, car is auto btw. there is no knocking noises coming from the engine and oil is topped right up so have no idea...
also i have recently put on a 2.5" straight through exhaust system on the car and noticed when boosting it now begins to miss when reaching full boost..(factory 10psi.)... am thinking new plugs and/or leads will fix this problem??? any help is greatly appreciated.
trdtrueno
Postby mjrstar » Thu May 07, 2009 10:43 am
May also pay to check fuel pump, fuel filter etc...
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby Mr.Phreak » Thu May 07, 2009 10:45 am
It's trying to tell you it wants to be a JZ :P
Mr.Phreak
Postby trdtrueno » Thu May 07, 2009 11:17 am
yea...a service is in order me thinks.......hahaha i wish....1jz would be nice!
trdtrueno
Postby cat007 » Fri May 08, 2009 9:31 am
Stalling after coming to stop after driving normally means BOV venting to atmo which is a no no with AFM's.
Check leads. Genuine or even knock off but in genuine style are going to hurt the pocket. I use generic (but thick and good quality) leads and I don't worry about the little dust cap that goes between the cam covers. Its pretty unnecessary
Postby trdtrueno » Fri May 08, 2009 10:17 am
thanks for the info....i dont have a bov on it at the moment though, just the factory one if it has one.
trdtrueno
Postby cat007 » Fri May 08, 2009 10:21 am
trdtrueno wrote:thanks for the info....i dont have a bov on it at the moment though, just the factory one if it has one.
Hmm - factory they don't have one.
What if you knock it into neutral before you come to a stop. Does it still stall?
Postby rollaholic » Fri May 08, 2009 7:50 pm
give the throttle body a good clean for a start
Postby trdtrueno » Sat May 09, 2009 10:21 am
i dont think it stalls out if its banged into neutral...that being said, oil pressure usually drops right down before stalling......could it be a sign that the transmission is on the way out?? maybe the auto is finally crapping out. if so time for a manual box.....is there anything that i can clean the throttle body with? or do i have to manually take it off and clean?? or is there an additive around that will clean it?
cheers for the info guys
trdtrueno
