Ae85 drum brakes locking
Postby rx7guy » Sat May 09, 2009 6:02 pm
I changed my front pads today, didnt bleed the lines or anything just squeezed the calipers out a bit. I also took off the left rear drum to check if the shoes were worn, but they were ok.
Now when I took it round the block the rear right drum locks up really easily, even though this is the one brake I didnt touch. I'm not sure, but it is possible the left is also locking.
I took both drums off and checked them after but there was nothing out of the ordinary I could see.
I've never done anything on drum brakes so im not really sure what to do. Do I just need to adjust the shoes?
The torque band is wide and the road is narrow
rx7guy
Postby rx7guy » Sun May 10, 2009 11:45 pm
Edit - Now fixed, just needed to adjust...
rx7guy
