Anybody Know What This Is Called?
Postby celica_xr9145 » Tue May 12, 2009 8:58 pm
Anybody Know What Part This Is Called?
Im on about the silver ring through the hole. Im not sure if its apart of the cv, the problem is that my celica currently has a cv for a 2ws celica, it is supposed to have a 4ws cv. It measures how fast the wheel is going buy using a speed sensor but the sensor on mine cant measure the wheel speed because there's no ring.
Im going to go to toyota tommorow and ask if they can get hold of the part for me but i dont know what im asking for.
Any ideas?
celica_xr9145
Postby unstable » Tue May 12, 2009 9:18 pm
tap the ring off the old CV and back onto the new one.
2000 JZX100 Chaser
13.827@167kph@ Nightspeed.
Owner- Pit Stop Grey Lynn. PM for Quotes.
unstable
Postby celica_xr9145 » Tue May 12, 2009 10:52 pm
unstable wrote:tap the ring off the old CV and back onto the new one.
thats the thing, only the 4ws one have the ring, it currently has a 2ws without the ring which is the wrong one.
Problem is that i dont know if the ring is attatched to the cv or if it pops of and can put it on to a 2ws cv.
I also dont know if they are different apart from the speed sensor ring.
Just found this aswell, looks like abs cv's have the same sort of system.
Could these be used or adapted to fit mine?
Last edited by celica_xr9145 on Tue May 12, 2009 11:13 pm, edited 1 time in total.
celica_xr9145
Postby Lloyd » Tue May 12, 2009 11:05 pm
Thats looking through the hole where the sensor goes at the teeth on the pickup ring that I couldn't see on your car. The sensor seemed to work fine on a scope (on your car) and the fault code was 41. There was a huge gap between the CV and the sensor where the pick up ring should have gone which is why the code was thrown most likely. It'll be a case of finding the right ring or CV for the vehicle.
Postby celica_xr9145 » Tue May 12, 2009 11:18 pm
Lloyd wrote:Thats looking through the hole where the sensor goes at the teeth on the pickup ring that I couldn't see on your car. The sensor seemed to work fine on a scope (on your car) and the fault code was 41. There was a huge gap between the CV and the sensor where the pick up ring should have gone which is why the code was thrown most likely. It'll be a case of finding the right ring or CV for the vehicle.
Yea i know, ive been searching but no luck, hopefully you guys at mlm will find one, could do with the car being fixed before the 22nd
celica_xr9145
Postby CelicaGT8 » Wed May 13, 2009 1:01 am
Its for the abs... nothing to do with 4ws and 2ws as both came with and without abs.
CelicaGT8
Postby Lloyd » Wed May 13, 2009 1:15 am
Wrong. Its for the 4WS.
Car does not have ABS, and yes thats the ring required. You cant adapt anything to suit. It has to be exactly the right size as its a press fit on there and needs the right tooth count. There are probably a few across the Toyota range that will suit but I couldn't tell you off the top of my head what will do the job
Postby celica_xr9145 » Wed May 13, 2009 1:27 am
Lloyd wrote:Wrong. Its for the 4WS.
aahh i get it now, bit wierd that the last 6 months the car had no ring and drove fine, and only now it finally goes wrong :?
celica_xr9145
