t3 VS t28/t25 turbo
t3 VS t28/t25 turbo
Postby tim_blair » Sat May 16, 2009 1:01 am
when putting a turbo on a blacktop
and given the choice of any t3 flanged turbo or t25/t28 flanged turbo what would be a better choice
where lag, size and placement are the issues not hp
tim_blair
Postby Burning Angel » Sat May 16, 2009 8:31 am
id say t28
my cousin has one off an S15 and it has awesome spool. at 100kph in 5th you can put your foot down and have boost straight away.
he had a quite big T3T4 on it and it was laggy as, but made good top end power.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby l1ttle_d3vil » Sat May 16, 2009 9:17 am
T2# series will definitely spool faster. They still give good power too.
dyno graph for my t25g is in the projects section if you want to look.
should be plenty floating around for the t3's too, theres quite a few graphs from various setups on garagedori.
Postby Bazda » Sun May 17, 2009 4:26 pm
I would run a T3 based turbo with a blacktop 20v.
These heads flow well and spool up small T3s very fast.
Postby strx7 » Sun May 17, 2009 5:31 pm
Burning Angel wrote:id say t28
if you cant have boost straight away in 5th gear, the turbo is MAJORILY too big for the engine it is bolted to............ :roll:
Postby matt dunn » Sun May 17, 2009 8:13 pm
100k is usually about 3000rpm in a toyota, so i wouldn't 100% agree with that.
Sure you may like that to happen on a street car,
but with aftermarket turbo's and the search for power....
my old hybrid T28 wouldn't have had a show of making boost at 3000 rpm, and it was maxed out at 300hp, and it wasn't just a s/h POS,
it was a specifically built one.
