~SlideWays~ wrote:Aren't there a few different variations of the CT26?
I doubt the one on a landcruiser diesel is the same as the MR2 etc?
DeeCee wrote:its not the one off mrcontrols power primer was it? Cos that is a T04E map.
http://www.mrcontrols.com/primers/sizing.htm
strx7 wrote:~SlideWays~ wrote:Aren't there a few different variations of the CT26?
a 4.2 deisel consumes similar volumes of air to a 2 litre petrol. I know the CT26 on a 7MGTE supposedly has a bigger compressor to the ones found on MR2/GT4
[HITONU] wrote:i thought a st215 caldina had a ct26 as well?
what does it have then?
Akane wrote:I heard a little birdie told me that the Supra CT26 is crazily huge, not only on the compressor side but also on the exhaust side.
But pity they don't fit 3S-GTE's or else it'll be a mean upgrade.
That dude who had his Supra with one of those CT26's plus upgraded comp wheel was almost kicking my buttocks at the drags, but then he had half a car plus slicks, cheater
Akane wrote:My guess is that you made a custom manifold for the turbo, since as far as I know it won't bolt up to the factory manifold. Why not choose a better and more common turbo instead of the Supra CT26?
strx7 wrote:Akane wrote:My guess is that you made a custom manifold for the turbo, since as far as I know it won't bolt up to the factory manifold. Why not choose a better and more common turbo instead of the Supra CT26?
Are you talking about me? or someone else?
Akane wrote:strx7 wrote:Akane wrote:My guess is that you made a custom manifold for the turbo, since as far as I know it won't bolt up to the factory manifold. Why not choose a better and more common turbo instead of the Supra CT26?
Thinking of what Scottie said. Why go thru all the trouble of mating up the Supra CT26 to the 3S-GTE? Should instead change to something more common and upgradable, maybe T25 Flange?
