18 slicks
18 slicks
Postby gtpornstar » Wed May 20, 2009 12:45 am
Anyone know whats the wdest tyre that can fit on a 9" rim ?
Trying to fit some 275's and hear it can be done but they are full slicks with a reinforced outside wall so a bit scared i will bust the tyre or it wont sit properly.
Toyota Starlet GT 90
Toyota Glanza V 96
Toyota Supra N/A 94
gtpornstar
Postby strx7 » Wed May 20, 2009 1:53 pm
a 245 or 255 will sit nice and true on a 9 inch wide rim.
Postby DRFTIN » Thu May 21, 2009 11:35 am
being slicks they will most likely be wider than a 275 road tyre too
my 255 semi's are slightly wider than the 9" rims
but give it a go, will either work or it wont, my guess is it wont
DRFTIN
Postby Truenotch » Thu May 21, 2009 5:07 pm
What are the 275's from? Get 2nd hand carrera cup front tyres, they should fit.
Truenotch
Postby gtpornstar » Thu May 21, 2009 11:43 pm
Thans for the help guys
Decided to just give it a go anyways, i got porsche cup 270 tyres, they fitted but were super high and because of the baloon effect it starteed to rub. So ended up putting the front 240's on the rear ... pretty sweet setup but would want to wden guards and get the 270's back on :)
Toyota Glanza V 96
Toyota Supra N/A 94
gtpornstar
Postby Truenotch » Fri May 22, 2009 1:25 am
What car is that on? 270 is pretty huge, you'd still have enough traction with a 240 IMO.
Truenotch
Postby gtpornstar » Fri May 22, 2009 2:40 pm
on a JZA80 supra, stock turbos still and 1.2bar and coming out of corners is where i loose time, 240's are a huge improvement over any road tyre but would need something wider like the 260-270 atleast, just need to see if i can find something that is not so damm tall :)
Did track 1 yesterday at taupo and was still easy to get sideways.
Toyota Glanza V 96
Toyota Supra N/A 94
gtpornstar
Postby matt dunn » Fri May 22, 2009 3:01 pm
wider tyres are not always the answer for grip.
I know that on the 6.5" rims I used to run the 205's gave much better grip that the 225's on the same rim as the tyre sat squarer and used more of the tread.
Also suspension design and setting make a big difference.
I believe you can over tyre a race car.
Postby gtpornstar » Fri May 22, 2009 3:08 pm
matt dunn wrote:wider tyres are not always the answer for grip.
you kinda need to compare tyres that both sit squarly as you say, so with the required size rim. Also grip powering out of a corner in a RWD is not the same grip required to take corners at X speed.
Suspension design - yup, also something to make sure you check in order to make use of your power and grip.
'Over tyre' - yes definitely but i would say you start to loose cornering ability and increase drag then.
Toyota Glanza V 96
Toyota Supra N/A 94
gtpornstar
