Width of standard ee80/ae82 13 inch steel wheel
Postby xsspeed » Fri May 22, 2009 10:45 am
Does anyone know the width and offset of a standard ee80/ae82 13 inch steel wheel?
I need to work out the back spacing to see if I can fit some alloys on it, that are 42p, 15x7
Postby Dell'Orto » Fri May 22, 2009 1:50 pm
I would imagine 6" at the very most, probably 5.5". What are factory tyre sizes, that'll give you a rough indication.
Postby xsspeed » Fri May 22, 2009 2:00 pm
The tyres I have on it at the moment I think are 165/70
My guess is 5.5, wouldnt think they are 6. Will probably have to do my best at measuring them tonight.
If I measure the width edge to edge, the bead width will be roughly 0.5 inch less?
Postby THA SHZ » Fri May 22, 2009 2:30 pm
they will more than likely be 5 inch wide . 8)
THA SHZ
