Celica with low idle
Postby 5OBAIT » Sun May 24, 2009 11:20 am
I took the battery out of a st202 celica to use to start another car last weekend. After putting the battery back in the celica, which is an auto, it now for some reason idles a lot lower at about 400 when in gear & about 800-900 in park.
Any ideas why it would have dropped? how to fix it?
5OBAIT
Postby DeeCee » Sun May 24, 2009 1:59 pm
Generally you just need to keep driving and it will come right. Used to happen to mine, sometimes even stalling (while driving lol). In the end, I just adjusted the idle control slightly to get it back up.
GT Four Adovansu
DeeCee
Postby ROBODISCO_20v » Tue May 26, 2009 4:14 pm
Altezza's have a similar problem, they way to fix it on them is to clean the thermostat/air temp sensor in the throttle boby.
Just had a quick look on ToyoDIY.com & it would seem '98 on ST202 have this same set up. Pay to clean you MAF sensor too if you have that later model.
ROBODISCO_20v
