I have not started my car for 5 weeks, last time i drove it everything seemed fine.
Last night as i was cruising at about 100 km/h i could feel a light miss every 5 seconds or so.
After about a minute it got worse and under load it felt low on power, another minute later it would not accelerate past 1/4 throttle and past 4000rpm.
This morning i tried it again and it runs fine at idle and free revving, anything past 1/4 throttle and it splutters very badly and will not rev past about 2500rpm.
I have tried bypassing the fuel pump ecu with no change.
It runs the same with the afm unplugged.
With the paperclip in te1 and e1 the o/d light flashes constantly which from what i can gather it means no fault.
Reset the ecu.
Opened the ecu up and checked for dry connections, eveything looks ok.
What would you helpfull chaps reccomend i try next?
