Stud Pattern Sprinter Marino
Postby Anton » Sun May 24, 2009 11:33 pm
I saw a chart in the internet that the stud pattern of my 98 Sprinter Marino is 4 x 100. There is a set of allowy wheels in Trademe that i want to bid on. Seller does not know if it will fit on a Sprinter Marino but mentioned that the stud pattern is 4 x 100. Does it mean that when the stud patterns are the same, the wheel will fit my Sprinter Marino. Thanks to anyone who can help with my question.
2003 Red Celica
1998 Sprinter Marino
Anton
Postby jakesae101 » Sun May 24, 2009 11:36 pm
yes if there 4x100 they will fit but you will want to ask what the offset is aswell
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby Anton » Sun May 24, 2009 11:47 pm
Thanks for the reply Jake. The seller does not know the offset but will it there be a possible problem with the offset?
2003 Red Celica
Anton
Postby rx7guy » Mon May 25, 2009 12:11 am
Your car should need around about a +35 to 40 offset, or the wheels will not fit under the guards properly. It depends how wide the wheels are.
If they have been on a fwd I imagine they will be ok though.
The torque band is wide and the road is narrow
rx7guy
Postby xsspeed » Mon May 25, 2009 12:22 am
Ask him to measure the backspace, if its aroune 120mm to 140mm you should be fine, assuming its been on a fwd
Backspace being the distance from the inner face that attaches to the hub to the inner most edge of the rim
Postby Anton » Mon May 25, 2009 12:40 am
Thanks for all the help.
2003 Red Celica
Anton
