Whats this 3s Gear box... ?
Postby Phothog » Wed May 27, 2009 7:03 pm
i have picked up an FWD LSD box...
it came off a 3sgte was going into a fwd car...
shift levers for fwd, looks like electrionic speedo pick up.
castings for mounting the shifter cables..
Can anyone tell me what it might be....
or even better does anyone want to swap for a MR2 LSD box w/axles...
Cheers,
Chris.
1999 ST215W GT-T 325,000kms still going strong.
2000 M201G YRV Turbo, 1300cc little pocket rocket.
Need a Turbo Rebuilt or Upgraded... send me a email Chris @ Turbo.co.nz
Phothog
Postby cedwards » Wed May 27, 2009 7:46 pm
looks very similar to a celica/caldina box
cedwards
Postby Malcolm » Wed May 27, 2009 9:20 pm
looks like an S series, can't remember which ones had LSD's but I think the SS2 or SS3 celicas had LSDs, so it's probably from one of them.
Postby GTTpower » Wed May 27, 2009 9:50 pm
S54?
1999 SXE10 Altezza RS200Z
2004 Honda SCV100
Previous: 1993 EP85 Starlet, 1984 KP60 Starlet
Steam/Origin ID: nzEP85
GTTpower
Postby KinLoud » Thu May 28, 2009 12:14 am
Just curious...
What makes you think it has an lsd inside it?
Usually an lsd box will look a bit different to your pic of the driveshaft hole.
Can you get a better pic?
Ken
Postby Akane » Thu May 28, 2009 2:44 am
It's a common believe that if your 3S box has a LSD, you'll see a hexagon shaped rod going through the middle of the driveshaft hole.
I don't know, the 2 E153 boxes I had both have the hex shaped rod going through, although my replacement box was bit weak on the LSD hooking up.
Postby Phothog » Thu May 28, 2009 2:47 pm
KinLoud wrote:Just curious...
Ken
i can get a better pic...
the camera was weged between the box & a 3vzfe..
and the other side still has the axle bolted into it.
as akane has said... as far as im aware a hexagon shaped rod going through the middle of the driveshaft hole means lsd....
and they guy i got it off, said it was LSD.... and thats what the previous owner told him as well.
thanks guys.
Phothog
Postby Phothog » Fri May 29, 2009 1:51 pm
Here is another pic of the lsd...
im thinking it's ST206 currren set now....
Chris.
Phothog
