what model engine you do have small port big port?
what intake manifold are you using?
Are the lines open or capped?
Have you set the TPS correctly?
i had a similar problem
with one years ago, some thing didnt quite match up and it had a vaccum leak,
themaleman wrote:water lines back up to the TB
would you say the tps not being set correctly would be the reason for the remaining high reves?
