Can anyone point me in the direction on info for the clutch in a ae111 bzr?
Need to change mine and want to know what the ins and outs are
xsspeed wrote:To get gbox out
-disconnect wires, clutch line etc
-remove starter
-take weight of engine with crane or similar
-drain oil from gbox
-drop out the cross member(s)
-undo gbox bolts to engine, and backing plate
-support gbox with something (I use a low rise tranny jack)
-undo gbox mounts
-lower gearbox and engine slowly (leaving cambelt side mount on)
-should get to a point where you can pry the gbox off
-pray that you have your car jacked up enough to wheel the gbox out underneath.
that how I do it anyway
fitting is opposite of above
xsspeed wrote:oh lol, yuh cv's, more often than not you'll need to drop the lower arm off the suspension to get eth CVs out, and remove the tie rod ends from the hub carrier too. (large hammer required as I found out)
