Ae86 rear strut tower
Postby rx7guy » Tue Jun 02, 2009 3:47 pm
Hey can anyone tell me if any other corollas (ke70 etc) share the same rear strut tower as the ae85/6?
I am wanting to reinforce my current towers with an extra tower welded on top. If anyone has any they would sell me that would be great too.
The torque band is wide and the road is narrow
rx7guy
Postby CelicaGT8 » Tue Jun 02, 2009 3:49 pm
Is it common to do that? if it fits over its self it should be quite good
CelicaGT8
Postby Mr Revhead » Tue Jun 02, 2009 4:07 pm
V6 capris had that to stiffen them up
why do you want to stiffen the towers?
you could turret them
Postby rx7guy » Tue Jun 02, 2009 5:23 pm
Ive got d2 adjustables with the spring on the strut, need to be stiffened for cert. This seems to be the cheapest way to do it if I can find towers.
Its either that or replace the adjustables with standard style setup, but im really poor right now, and I would like to get it certified for adjustables all round.
EDIT: What do you mean by turret?
rx7guy
Postby frost » Tue Jun 02, 2009 7:55 pm
the japanese guys like stitch welding rather then adding another tower, you might run into rust problems later if not protected straight after welding. as thats what made them rust in the rear inner guards and door jams.
Postby CelicaGT8 » Tue Jun 02, 2009 8:18 pm
Roll cage. or a rear brace, my coilovers are stiff as and i have no probs
CelicaGT8
Postby Truenotch » Tue Jun 02, 2009 8:29 pm
Turrets in a KP starlet.
Truenotch
Postby Mr Revhead » Tue Jun 02, 2009 8:31 pm
rear brace wont do much in the way of what he's after.
my advice, ditch the D2s and get some real suspension
but if you are determined to keep them, then maybe see if a beater can make something fit.
http://www.rwd-escort.co.uk/images/carl ... urret5.JPG
see the new steel boxes being added?
Postby rx7guy » Tue Jun 02, 2009 8:59 pm
I think I will just have to track down some lowering springs and struts. Those starlet turrets look mighty delictable though. Thanks for the help.
rx7guy
Postby Rick » Tue Jun 02, 2009 10:08 pm
So the certification guy spotted the D2's in the rear and said the mounting point on the car needs to be stiffened or he wouldn't pass it???
Postby Mr Revhead » Tue Jun 02, 2009 10:11 pm
makes sense.
from the description the d2s are taking the load from the factory spring area, and putting it through the shock towers.
which were never designed for it
Postby Dell'Orto » Tue Jun 02, 2009 10:15 pm
What about the mounting pins on the diff? They're not designed for that kind of load either.
Postby rx7guy » Wed Jun 03, 2009 3:36 pm
Yeah thats right, he doesn't like all the load going through the mounting point. Just gotta hope the pins are strong enough I guess.
rx7guy
Postby Mr Revhead » Wed Jun 03, 2009 4:22 pm
i would say they are
Postby Truenotch » Wed Jun 03, 2009 8:21 pm
Why not just use decent coil springs and a separate shock in the rear? It'll handle better with TRD springs and some decent heavy shocks.
Truenotch
Postby rx7guy » Sat Jun 06, 2009 2:30 pm
Ok, I am interested in the seperate shock and spring setup. Who in NZ sells adjustable height springs only?
Like this: http://shift-lock.netfirms.com/modstore ... C_0355.jpg
EDIT: Looks like bc have what i'm after but I'm not sure if they sell individual components.
rx7guy
Postby Truenotch » Sat Jun 06, 2009 8:55 pm
Yeah thats a good way to do the setup.
Any real reason to go adjustable in the rear? You can still get good handling and height without it.
Truenotch
