Caldina Mines ECU
Caldina Mines ECU
Postby bbq1988 » Tue Jun 09, 2009 10:20 am
Hey guys, does anyone know if an MINES Ecu for a Auto caldina will fit/work on a manual?
Baked, Not Fried.
bbq1988
Postby fivebob » Tue Jun 09, 2009 11:48 am
Probably not as it would get errors because the ABS/VSC and Transmission sensors were not connected.
However, even if it did work why would you want it???
AFAIK it's not tunable, would likely have a more agressive ignition map than the standard ECU and would cause even more problems running on the shit NZ fuel than the sock ECU.
FWIW my Caldina came with a HKS FCON-S piggyback ECU which is tunable but only by an HKS approved workshop. It only gave about 10HP more and probably contributed to the engine failure I had, so I removed it when I installed the new engine.
Postby bbq1988 » Tue Jun 09, 2009 11:58 am
oh, cheers for that. Just seemed like a good idea at the time
Baked, Not Fried.
bbq1988
Postby phraza » Tue Jun 09, 2009 1:00 pm
is that the one on trademe? i was looking at that thinking the same thing... lol
2WD 06 Hilux
phraza
Postby frost » Tue Jun 09, 2009 9:10 pm
i looked into it and no it wont work. too many error codes to make it worth while.
