Hey all
If I have a 12v-240v inverter and the device I'm running uses 240v and 260 watt - how many watts @ 12v will it draw from the battery?
Is it goign to be 260W or will it change somehow because its stepping down/up to 12v....
cat007 wrote:Hey all
sergei wrote:How many watts? if inverter efficiency is about 60-80% so then it will draw 300-360W.
Perhaps you meant amps? roughly 25A-30A.
Power=Voltage * Current.
How long you battery lasts? If it is a standard NS40 style, under 1 Hour.
cat007 wrote:sergei wrote:How many watts? if inverter efficiency is about 60-80% so then it will draw 300-360W.
I have one of these: http://linux.supercharge.com.au/product_detail.php?seq=84
The inverter is an 800-1000 watt continuous (1600-2000W surge) - is that the 240V power rating? 800watt @ 240volt is 3.33amps - but 3.3amps @ 12volt is only 39watt??? I'm confused as hell lol
