KE30/4K wiring help..
Postby RS13 » Thu Jun 11, 2009 12:22 am
Hi guys,
I'm after some advice/diagrams for a '76 KE30, I need to know what coil wires go to where. The car had a "GT40"-type coil in it but it wasn't running well, so the current owner had a mate cut and splice a few wires to reinstall a factory DX coil, but it still won't spark.. there seems to be a few random wires that don't do much that have been added as well? Hmm.
Any help would be appreciated! :)
RS13
Postby AE25 » Thu Jun 11, 2009 12:17 pm
the fat positive power wire (i think black/orange) runs thru a resistor (the white ceramic thing) to the positive terminal on the std ignition coil. if you are running a points dizzy, the dizzy wire connects to the negative terminal of the coil. if its an electric dizzy.. the two wires connect to both terminals of the coil. if its a points dizzy it should also have a capacitor on the dizzy wire connected to earth to take away voltage spikes (stops jumping the points gap when not supposed to). if you have aftermarket coil that has internal resistor or have points dizzy then do away with the ceramic external resistor.
E2 & E7 fanatic
http://www.toycrazy.net
AE25
Postby gepsk8 » Thu Jun 11, 2009 11:32 pm
damn one of the best question and answer i've ever read on toyspeed!
this should be used as example
O272754663
gepsk8
Postby RS13 » Fri Jun 12, 2009 12:42 am
AE25 wrote:the fat positive power wire (i think black/orange) runs thru a resistor (the white ceramic thing) to the positive terminal on the std ignition coil. if you are running a points dizzy, the dizzy wire connects to the negative terminal of the coil. if its an electric dizzy.. the two wires connect to both terminals of the coil. if its a points dizzy it should also have a capacitor on the dizzy wire connected to earth to take away voltage spikes (stops jumping the points gap when not supposed to). if you have aftermarket coil that has internal resistor or have points dizzy then do away with the ceramic external resistor.
Awesome, thanks man. :)
RS13
